Hey Everyone, I'm new here but would appreciate some help. I have an Asrock B450 pro4 that I have been having fun with for almost a year now. I've been teaching myself how to OC the memory with the Ryzen DRAM calculator and my own trial and error.
A few weeks ago something went sideways with the OC Tweaker tab. Changes to settings are saved but aren't reflected in windows when it boots. I've restored the default values in Bios, reset the bios via the MB jumper, pulled the CMOS battery, switched memory locations and number of dims but nothing changes. I've even switch memory with my daughters PC to see if it made a difference. My memory in her PC works fine but her memory in my PC has the same behavior. I can set the memory to 4000mhz cl10 and bios will save it (it doesn't train the memory though so it never does the three startup attempts) but it will still boot and show 2400mhz in CPU-z. Load BIOS again and its still set to 4000mhz. I uninstalled Ryzen Master thinking that it might be a potential conflict but there is no change.
I would upgrade the bios to 3.6 but there is a disclaimer on Asrock's website stating that its not recommended 2000 series CPUs. Rolling back to an older version wont work because there is a disclaimer on the current version that I have stating that you I cant roll back to the previous version.
The build is:
2600x on the Asrock B450m PRO4 with P3.50 bios version
Crucial BLS8G4D32AESBK.M8FE
Corsair CMK16GX4M2B3000C15
(Memory was tried separately not all 4 sticks at the same time)
Sapphire 5600xt
NZXT 400 something (Plenty of airflow)
Intel NVME
Intel ssd
Toshiba HDD
620w Seasonic PSU
I monitor with CPUID's HW Monitor and CPU-Z
I contacted Asrock tech support a few days ago but haven't heard a thing. I'm running out of ideas. Can anyone offer some new suggestions?
Thanks and sorry that this was so long.
Matt
The build is:
Sapphire 5600xt
Intel NVME
Intel ssd
Toshiba HDD
620w Seasonic PSU
Matt
Still quick
