Switching from air to an AIO
21 May 2018
South Wales
Any recommendations on a decent 240/280 AIO?
Just installed a Corsair H115i Platinum in my daughters setup and kind of want to upgrade mine now!
Also noticed some kind of rattle noise like air bubbles coming from the pump although it's extremely quiet.
arctic liquid freezer 2 gets very good reviews should look into it.
am happy with my h100i pro xt though and i have had zero issues with it (touch wood)
Most AIO's that are on sale are great. I have the Corsair H60 single vent where as you got the double one there. Mine has no vibrations or bubbles but not sure how you can tell it has bubbles on that unit though. :)
Most AIO's that are on sale are great. I have the Corsair H50i single vent where as you got the double one there. Mine has no vibrations or bubbles but not sure how you can tell it has bubbles on that unit though. :)
Sounds like a rattle and after a quick google it turns out many had a similar experience and say it calms down after awhile, air bubbles apparently... so I'm in the market for an AIO.
Got an Arctic 240 waiting to be installed this weekend. It was only £60 on preorder and nothing could touch it for value. At its current price of £75 its still pretty solid. I really like the single wire for the pump and fans.
Ive seen some reviews mention the single cable as a downside :confused:
For me personally it’s an awesome thing.
Any ideas on performance delta between the 240 and 280?
