Hi guys! So I brought a pc a while back and now the system is starting to struggle. Doesn’t help my cpu is bound to 3.4ghz due to a hp motherboard. I got recommended to go on here to see if someone will know of a alternated bios I can use to unlock the rest of the features. Manufacture-HP Product-828A Serial Number-PFXGR0C0Z495CH version-1.01. I know the risks but I’m at breaking point with this pc. I have a rtx 2070 super but my cpu is an i7-6700 non k. And I know they can overclock to 4ghz. Thanks guys!
Personally if the motherboard has been manufactured specifically for HP systems I think you will be lucky to find a non standard BIOS for it. Your best bet would be to check the motherboard to see if you can find some markings to indicate the manufacturer and model number, then see if Gooogle can come up with anything.
I have 16gb of ram to and a ssd
