Phanteks Luxe 719 pump mounting...
If those images show everything you have, then it looks like you could bolt it to one of the 120mm fan spaces on the bottom of the case.
Failing that, you could spend a couple of quid on any number of different circlips, reservoir brackets and so on, not necessarily EKWB brand either. I'm guessing 60mm diameter?
I have a similar case and mine is mounted on the rear panel just in front of the graphics card. A common favourite is putting the assembly to the right of the motherboard.
See here for more ideas: https://www.google.com/search?q=Lux...XoSxUIHTpqDLoQ_AUoAnoECAwQBA&biw=1620&bih=851
Here's mine with the newer version ek xres combo
And yeah you can get the DDC mount for older version that allows mounting it on a 120mm fan space
Do you not have a fan in that top rad slot, and what's that clear tube thing occupying the space?
There's fans on the other side too
So 7 fans on that rad already so missing 1 doesn't really matter lol
That clear tube thing is my backup pump and reservoir and another 360mm radiator ~it's a swiftech 360mm premium expandable AIO
Yeah I know it's overkill on radiators but they were laying around anyway so cost nothing
Oh I'm not being derisive mate; just curious. I've often had to run without a fan or two for clearance, and I'm a big proponent of the moar rads movement :D To be frank I don't think it's overkill, the rad space and push/pull means you can keep fan speeds low.
Slowly putting together my next build and it's going to have at least 2x 360 + 240, and dual D5s in series. So I won't be throwing any stones :D
Is the Swiftech off normally, and just there for redundancy? (I thought it was a no-no to run two different pumps in the same loop)
It looks dope, is it all built into the rad? Any more pics of it?
Oh I didn't think you were being derisory mate so no worries there
Not having the top fan on the 480mm rad
Allows filling into the swiftech as well as into the bottom ek res/pump combo
Being able to top fill means mavity helps you out and can release air bubbles easier as got a pressure equaliser/release valve at top of loop
Plus when draining opening that top release valve means no air locks
No problem at all running both the pumps
Done it for many years
But have also tested with either pump disabled and either pump on its own works fine so if 1 fails redundancy works great
The pump is at the rear of the reservoir so not technically in the rad
Long time ago asetek sued swiftech for having the pump in the block
So far as I am aware swiftech was the first AIO company to move the pump up to the radiator end to avoid asetek patent infringement
Think that ones the 3rd series swiftech and the premium version means proper g1/4 fittings not plastic barbs, noise blocker eloop fans and some other stuff
Picked it up for a steal on ebay as lot of
People aren't aware of swiftech
Guy bought it never used it and I won it for 40 quid
Felt sorry for the seller to be honest
Though great bargain for me
Might have some photos of it on my pc somewhere will have a look in a bit
Swiftech is hard to get in the uk but it's quality components in it unlike corsair etc
Though more AIO are slowly starting to use better components now
Big advantage is swiftech is expandable
So great way to start off with watercooling and then move forwards
Just finished a pc going to sell with much simpler loop
That's a version 2 swiftech 280mm
Expanded to cool a 7700k and a gtx1070
No 2nd pump or other rads
I love swiftech stuff lol
It's a shame outside the USA they haven't made it big with their stuff to be honest
Thanks for all the info mate, interesting. Never really used modular AIO systems. Liked the look of the (doomed) EK Predators when they came out though.
Only AIO I had was an h100i v2; didn't scratch the itch, so went back to custom loops :D
Gathering parts second hand for my next build. Will be run by AquaSuite, excited to give it a go.
Only AIO I ever used non swiftech was a corsair h80
But I immediately saw drawbacks with having a sealed cooler
If pump fails people bin the whole unit
That's wasteful to me I never bin stuff if there's a chance of repairing it
Just replaced the v2 swiftech pump on the pc I am selling turns out it's a ddc
Just altered a little by swiftech
And back in the old days gpus were much louder and hotter
So the H80 had no way to help with that
Without some serious ghetto mods
So when I spotted swiftech and noticed it could be expanded I grabbed one
EK predator basically copied swiftech by moving pump up to radiator end and using good components
So shame they weren't successful
Think ek just released a new AIO though not sure if it's a cheaper aluminium one
Aimed at corsair etc or a new attempt at a quality one will have to go read a review
To see
Aquasuite sounds interesting
Never bothered with flow rates or coolant temps etc just went by cpu temps and gpu temps
And visually checking does my flow look right
Always liked the look of an aquero though
Water temps makes a huge difference, as you don't get speed spikes, and the fans adjust speed based on how saturated the water is getting. I'd really recommend trying to plot your curves with it.
Dope that it's a DDC, awesome little pumps; insane head pressure. I think there was a recall on the original Predator, they were ahead of the curve for 'mainstream' CLCs.
AquaSuite and the AquaComputer range of products is incredibly powerful, with custom software sensors etc. Flow monitoring is most useful for noticing performance degradation, part failure etc. They have custom cables including those that can force a hardware shutdown on event, or interconnect various parts. AquaBus makes connecting everything up super easy, and avoids loads of USB extensions and adapters.
You can also turn fans on / off, and run them based off things like Delta T between case and ambient. Or turn on banks of rad fans as demand increases. Their NEXT and VISION ranges are dope too.
I also really like AquaComputer reservoirs; borosilicate glass & delrin, hydrophobic coatings, level sensors etc.
Don't have the cash to go crazy though, I mostly drool over the website and wait for parts to pop up on the MM. Hence the slow burn build :D
And it all integrates into what is objectively the most powerful control suite on the market, can't 3ait to give it all a go.
yeah it always comes down to the cash lol
4 more weeks i qualify for MM finally :)
hope its not too disappointing after the wait lol
yeah i prefer glass reservoirs definitely over acrylic
not tried aquacomputer ones
but got xspc photon and the glass ek x3 version
i tend to just set my pumps at 2000rpm cant hear them
and over that seems to make little difference to my temps --or within margin of error
not really done any really scientific based testing on it though
too much bother lol
used to love martins liquid lab for his great testing of stuff
the fans are set 700rpm up to 1000rpm max so those are really quiet too
guess the extra rads and extra coolant with 2 reservoirs may play a part
always wondered if you had enough coolant would there be a point
the system couldnt heat it past therefore making your temps lower
