Razer Deathadder Alternatives
25 May 2012
Hi,
I have used 4 Razer Deathadder mouses and the build quality seems to be dropping every new one I purchase whether the infamous double clicking stars, the rubber grips falling apart from the sides or the mouse wheel stops scrolling or clicking.
I am looking for a mouse which has similar shape to this (I am a right handed) and I think I prefer palm grip after trying out a entry claw grip. The mouse should not have any acceleration and have a decent sensor alongside it.
Can you guys suggest any good alternatives please?
Hi,
This is good for comparing sizes and shapes
https://gearsearch.gg/shape.html
I tried the DAv2 for a few days but ended up buying the Kain 120, model M looks similar is size too. I didn't like the dipping m1/m2 buttons on the DA as it forced me to palm it more plus was very soft to use.
Thanks, I dont think it covers all of the mouses in its database but stil should be useful.
I am not sure if the Kain is for me, I am very used to the deathadder and will need something that is literally a clone of it but one with better build quality, I am not sure if they have improved on the degrading build quality in the v2. I had a look at found the red dragon m711 cobra fps, it seems to share a lot of similarities to the DA.
After my deathadder i got a Zowie EC2-A (which is now the EC2-B) Found it to be pretty much my perfect replacement, has a fantastic shape and weight to it although the mousewheel is pretty darn cheap!
I'm thinking about the 2019 ec1 and ec2. They look very interesting indeed. Which shapes mimics the deathadder most do you think? Also which would you recommend for competitive fps gaming.
