Compressed air/Rubber blowers?
I'd like to clean the fans inside my PC and just wondered if those rubberball blowers you can buy are just as good as cans of compressed air?
I've never used one but I've seen them. I'll bet a pound to a penny that its a LONG way short of adequate pressure.
I use my air compressor, but if I didn't have one I'd buy a DataVac or something similar, mains powered. I know it's called a vac but it blows, big time! (not in a bad way)
I personally don't like the aerosol cans of air because of the crud they spray on your components, I know a lot of people use them but they're expensive, don't last long, aren't that good and create a lot of waste...
They’re intended to blow small dust particles out of cameras and won’t have anywhere near the pressure or volume you need.
Either borrow a compressor or have a friend power one of those large inflatable pumps while you direct the airflow.
