- 27 May 2020
Just got one of these laptops and it seems to be running quite hot - clocked the CPU at a max of 94C just playing the Sims, albeit with maxed-out settings (my daughter, honest
!)! Seems to run at mid 70s just in general usage.
Is this normal? It is sitting on a flat wooden desk. We even elevated it slightly to help with air flow. The room is hot but still...
I think it is rated at up to 105C but if it is hitting 94 under fairly low usage I wonder how long the chip will last...maybe there are bios settings I should tweak?
!)! Seems to run at mid 70s just in general usage.Is this normal? It is sitting on a flat wooden desk. We even elevated it slightly to help with air flow. The room is hot but still...
