Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
Usually only when I replace the motherboard when changing platforms or if I change the boot drive for any reason otherwise it's left alone.
Every 2/3 years or so, or new NVME drive.
New motherboard = reinstall.
I don't install much on mine, Steam, Winamp, Chrome. Keeps it nice and clean![]()
I tend to listen to one album over and over for a month. So dragging a folder into winamp does me fineWinamp Eh? How does it hold up in 2020 vs things like MusicBee?
Only when there's a reason to:
- New build
- Something's seriously broken
- To pass on an old PC to someone else
Otherwise "it aint broke don't fix it".
If you sign in to windows with a microsoft account, you should have a digital license attached to the laptop. Just do a clean install skipping any options to enter a product key and it should activate when you sign in again.
You can check beforehand by checking your MS account online. There will be a "manage devices" page somewhere.
I don't really know anything about recovery partitions but I doubt it's much use since you've upgraded. I can't say for sure though??
Being the nerd I am, I'd create a bootable win10 USB stick but of course you'd need another working windows machine for that. I'd then zap the hard drive completely but you might to use the diskpart command line tool. Have you used it before?
edit: I'd try and grab version 1909 of windows 10 just in case the latest 2004 really does have issues with your machine.
Thanks I will give it a try and let you now how I got onAs @marc2003 said, put the Windows 10 installer on a USB stick, boot from it, use diskpart to completely clean the drive you are installing onto, then install Windows 10.
Boot up from the USB stick and when it asks for your language press Shift + F10 to bring up a command prompt. Then type in diskpart and list the disks by typing in list disk and make sure you identify the right drive. If your disk is drive 0 (normally is), type in select disk 0 then clean to erase everything from it.
