Does my PSU have enough connectors?
27 Mar 2016
Bristolian living in Swindon
Hi all
Looking to get the MSI RADEON RX 5700 GAMING X 8GB which has 2x 8 pin power connector, I just want to double check my PSU has enough connectors before buying...
My PSU is a
Seasonic Focus SGX 500W Fully Modular 80+ PSU/Power Supply
Thanks
Bargain cheers bud... Does it matter that they're on one cable if you get what I mean?
It shouldn't do. Some cards prefer two separate cables from the PSU, and it's almost a requisite for the higher-end cards. I'd imagine a 5700 would be ok on a single daisy-chain cable though.
If it comes with two 6+2 connectors on separate cables, I'd recommend to use them both from the get-go, it's one less potential hiccup.
OK bud thanks for that... I'll dig out the box as I may have another connector in there I missed.. Cheers
