AMD Raise the Game bundle and Xbox Pass
27 Mar 2016
Bristolian living in Swindon
Hi all
My new GPU came with the above items, In the email i have redeem codes... Do i log into AMD Rewards and enter the bundle code for the games as i will probably have Resident Evil but not Monster Hunter..
Also with the XBOX Code i wont have it but dont know how to redeem that code, is that also on AMD Rewards?
Cheers
Hi all
Cheers
Hey mate,
When you log in to the AMD rewards it'll verify you own the GPU first, then you enter the code again and it'll attach the codes to the AMD rewards account, you can then choose which games you want to redeem.
If you're looking to sell the games you don't want then I suggest you start an email account just for this and not with your normal email, because your 1 AMD code attaches all 3 games to that account, you can't spilt them, so if you get a throw away email address, use that for the AMD rewards account, redeem your code and then pass on the rest to the new buyer?
Hey mate,
If you're looking to sell the games you don't want then I suggest you start an email account just for this and not with your normal email, because your 1 AMD code attaches all 3 games to that account, you can't spilt them, so if you set a throw away email address, use that for the AMD rewards account, take your code and then pass on the rest to the new buyer?
Ok cheers bud, I will set up a throw away email tomorrow for this then as i will pass on the other bits that come with the GPU... So all 3 codes get sent to that email and i just erase the one i take? Correct, sorry if it sounds silly, not done this before :)
No worries, it's easier once you see it in action :)
1) Set up a throw away email account.
2) Sign up to a AMD Rewards with your new email address from step 1.
3) Use the code you received from the Shop into the AMD rewards account.
4) You'll be prompted to download and run a verification tool.
5) Once you've passed this you'll need to re-enter the code from step 3.
6) This will then attach all 3 games to your new AMD rewards account (with the new email address).
7) Redeem your game of choice, this'll then leave the other 2 games still there (your redeemed game will still show but don't worry, once it's attached to your Steam or Origin etc...)
8) You can now sell the other 2 and give the new owner the AMD rewards log in info (throw away email and password to the rewards account).
You'll need to sell the last 2 together as you'll need to give the account to the new buyer, they can't be split, unless you totally trust the first buyer to only take 1 code that you've sold them?
Hope that makes it clearer? :)
Perfect, a lot easier to understand that way, Thanks bud :)
@Space Monkey I've decided I'm selling the whole bundle and pass... Do I just give them the code from my normal Gmail account that I recieved yesterday?
If they have an AMD GPU that can pass the verification then yes, just give them the code otherwise, get them to set up their own AMD Rewards account and give you the log in info for that, you then verify and attach the code to that account for them, they then can change the password when finished and redeem the codes at their leisure :)
OK bud thank you
