 - 15 Mar 2020
Hi, i'm in the process of getting parts together for a gaming pc build and was wondering what AMD motherboard would go best with a Ryzen 7 3700x or a Ryzen 3800x
Could i please have some recommendations for a micro ATX motherboard, also 16 GB of RAM
I'll either be buying a RTX 2080 super or a RTX 2070 super GPU
Any help's appreciated
- Needs to be a micro motherboard to fit my current case
 - Wifi/ Bluetooth and RGB lighting is not needed, my case is not windowed
 - My budget for the motherboard's £200ish and £80ish for the 16GB of ram
 - Future proofing is needed as i would like to upgrade parts in the future
 which was a bit worrying but that was because i had to take out the 120mm intake fan to fit the GPU plus i'm air cooling the CPU so that's heating the case up quite a bit, i prefer air coolers though because they're more reliable/ safer (oh i'm using a Noctua NH-D14, i think there's a newer version of this out now).
