Desk extension
I now need a new rug, a square one
But its awesome, it's added a full meter onto one end. All the space. Full blown desk rearrangement needed.
Before in case anyone wanted a reference.
For the past year or so, I've used my old motorbike rucksack (Kreiga) when cycling, but I finally got an actual cycling backpack...
Seems quite clever, it's got a mesh frame at the back to keep the actual backpack off your body and let the air flow... which was always a bit of an issue with the Kreiga. The increased possibility of a sweaty start to the day.
Desk extension...
Desk extension
That is so chavvy, what's next a corner sofa for the other side of the room?
Hey!How are you finding the Streamcam? And also if you painted it... what colour is the paint on the wall?
Hey!
Love the Streamcam, really pleased with it
I did paint the walls - here is the colour. https://deco.cin.com/pt/en/blue-revelation-e703-sea-clay-4
I know its a Portuguese brand, but if you like it hopefully you can find something similar to it in the UK- depending on the light its either a blue, a grey or a green. Generally it sits somewhere sort of in the middle of all of that. I like it, its very calming
Excellent, thanks. It's more or less the exact colour (as it appears on your walls) I had in mind for a new home office set up, though it does look greyer in the link
Still pretty though![]()
A lot to do!
