- 16 Nov 2011
I currently have a fairly old PC, but it doesn't get used for too much in the way of gaming so I have never been too bothered about upgrading in the past
Recently I started playing a couple of newer games where the minimum/recommended specs are above what my graphics card currently is - they play okay, but it would be nice to up the settings
PC
Asus Z97 Pro Gamer
Intel i5 4690k
2x4Gb DDR3
GTX560ti
Resolution - 2560x1440
So my question is whether it is worthwhile upgrading graphics to something like the RTX2060/2070, or to upgrade the entire machine
I don't have a budget for either, but I am not going to drop a 2080 in the machine just for the sake of it, if a 2060/2070 will be a reasonable upgrade that will last for quite a while with the rest of the machine
I was looking at the RTX2060 at just over £300, or is it worth paying another £100 for the RTX2070
PC
Asus Z97 Pro Gamer
Intel i5 4690k
2x4Gb DDR3
GTX560ti
