 - 26 Sep 2017
 - In the Masonic Temple
Noooooo my top placeany chance of an update Mr.Kaapstad, lets kick get some more scores added![]()
Noooooo my top place![]()
I'm on a 2080ti black evga, so I can't swap bios, but I have probably the best binned b chip in existence can hit 2160 and 87001440p wasn’t as easy! Needed a lot more gpu clockage and my 2080ti isn’t great might have to try the 380w bios...
Thanks for that, it is indeed your ram that has gained you 10fps over my friends 10900k,what type is it. I'm guessing it's trident z like mine.5.2GHz with 5000mhz ring bus
1.335v in bios with load line a medium load line. All 10/20cores goin no disabled ect
is my 24/7 stable clock.
I can push 5.3 but needs 1.38 and can just about Cinebench at 5.4 at 1.4’butneay to hot for anything else, need a custom water loop as I’m only using an old 280 aio NZXT.
mem possibly helps at 4400mhz cas16/16/17/36 2T and 280trfc. At 1.53v
most other junk set to auto tbh, I’m using an msi unify board so VRMs are decent.
gpu I can only go 2025 everyday 2100 at a push.
Nooooo you could have just stayed away lolScoreboard updated.![]()
Viper steel series 4400Thanks for that, it is indeed your ram that has gained you 10fps over my friends 10900k,what type is it. I'm guessing it's trident z like mine.
As the weather is a bit cooler I might try and beat yours this week, don't think it's happening though
3950x 4.6ghz 8 core + 4.3ghz 8 core
2080ti @ 2175mhz / 8500mhz
446.14 driver
sorry @FireTwo ;P + @TT158
cpu validation - https://valid.x86.fr/egbrnp
Although I don't think I can beat these scores from you and the other guy
@FireTwo can you tell me your 10900k settings? Volts and ring ghz? Hyper on or off, all core or just boost.
Asking as my friend ran this bench on his 10900k at 5.4ghz and got 334 cpu computation average to your almost 400 and only 120fps average
I use evga x1 precision to get higher than +1500 on the memory. It's goes up to 3000 max on thereDo you have w guide to bios swapping? Also, can you raise voltage as well as power limits with the custom ones?
I can help you with the bios flashing, no problem, what card do you have? I'll even find which ones you can use if you want.
You can only raise the power limit, the voltage slider doesn't do anything unfortunately.
And yes i have a heatkiller iv block on it and custom water cooled. I had to cool it to 31.c to get these scores![]()
Whatever keeps it cool my friend!Frankenstein looking mess with two 40mm Noctua fans slapped onto the end of the G12 bracket to cool the VRMs near the rear IO of the card!
446.14 driver
