Stock cooler or new one?
What sort of temps are you getting with the stock? I'm going to say near mid 70's maybe?
What sort of budget would you like to spend on a new cooler?
Currently 72ish. Just looking for suggestions really for my case and MB(if that effects anything?) but if I was to budget it I’d say £100 is max maybe slightly higher depending on the product
At that budget I'd consider the BeQuiet Dark Rock 4, the Noctua Nh-D15 is a highly recommended cooler but near on £100...
What is the PC used for? Gaming?
Yeah pretty much just gaming currently. Hopefully streaming further down the line. I’ve heard good things about Noctua. Just needed advice as I’m new to this and it was my first build so needed to check the dimensions and compatibility with everything
I'd say £100 was excessive - you may as well have bought a 3700x and got the better "stock" cooler with it
Just checked the Noctua NH-D15 and it's 1mm to big for you case :eek: the thing is huge :p
Would you consider an All in One liquid cooler
I’d consider liquid cooling too.
ahh okay thank you for all the suggestions I’ve heard good things about the mugan 5 too.
