psu making odd noise under high load
2 Jan 2005
somewhere
Hi,
i am using a Golden Green HX 750W "80 Plus Gold" Semi-Modular Power Supply that i bought in 2005 from ocuk and its been making odd noises when my graphics card is under heavy load.
It only happens when my 1070Ti is working at 95% or more (and the gpu power is 95% or higher as shown by afterburner).
Its not coil whine, its sort of a crackling or quiet sharp 'ticks' - a bit like a fan catching but i'm pretty sure it isn't the fan.
is this a problem?
or fixable?
cheers
You certainly didn't buy 80+ Gold PSU in 2005, because whole raing was announced some years later.
That's ancient 80+ PSU.
Would suggest replacing it already because of age.
There can be any number of reasons why a component might tick, but if it's only under heavy load and the pc is otherwise stable i wouldnt worry about it. Just keep an eye on the 12v rail (with a multi meter, preferably). Also if you dont already, try limiting your framerates as that can really help with weird squealing and ticking.
yeah its rock stable, never had a problem.
i can put up with the noise, i was just worried that it might mean potential failure soon.
Sounds like my toaster as it heats up and cools down.
Is it still under warranty?
If it's out of warranty, you could take it apart and give it a good clean and visual inspection to check for signs of overheating/fan catching/something moving/flexing.
nope, not under warranty.
i had though about opening it up but i'm a bit nervous about doing so - i usually take things apart but i've never done it to a psu before.
You need to let it sit unplugged for a period of time to allow the capacitors to drain or else you could get a nasty electrical shock from them.
If in doubt and you don't feel confident, don't do it - perhaps you could find someone who can do it for you?
There is no guarantee that taking it apart will solve your problem anyway: If you find a fault - can you fix it? If you don't find a fault - would you trust it?
Perhaps it's best to look for and buy a new PSU whilst there are still a very few left in stock (not many, but there be none at all in stock soon).
cheers, i'll have a think and see if i'm brave enough:)
