Hi all,
Fitted the waterblock to my Radeon VII over the weekend - and the rest of the support bits. Not exactly the neatest install (or the best pics) but it's functional and no leaks.
Pics were before filling and leak testing.
Need to try and organise the cabling a bit better (was just trying to keep things clear of the rad).
Probably something to sort out at some point later :-
- Drain point.
- 90 deg adapter on inlet of cpu block (although might mean tighter bend in rear section?)
- Temp sensor(s) and some means to hook them up for reading.
Thought that keeping pump outlet straight would help with flow/pressure? Could put a 90 or 45 deg adapter on pump outlet for tighter lines? Only had a couple of 90 deg adapters which I used on the short section of between rad and pump inlet.
Could put a 2nd rad in the top, but don't think I have much clearance there for anything other than a thin 140 or possibly 240 rad. Temps seem fine at the moment though.
I bought items that were in stock. In hindsight, probably should have gone for a shorter res, and not a d-rgb one since it's hidden in the back. The blocks are also "normal" rgb too, so not a match - although probably only use to try an implement some sort of temperature driven colour change for visual monitoring.
- Drain point.
