I can't beat that, I tip my hat to youOK. I think that this is about my limit unless I stump up the courage to do this bios thing. The floor is yours
3900x stock 3.8 - 4.6ghz
2080ti @ 2145mhz / 8350mhz
446.14 driver
Yeah, it showed me that I could push my system more than I thought possible, I had 8 cores at 4.6ghz, it was nice.All fun and games. The best thing about this is that it made me have a play on FH4 again and damn it's good fun!
Are you planning to play forza for a while, I need some in game buddies
I use evga x1 precision to get higher than +1500 on the memory. It's goes up to 3000 max on there
I can help you with the bios flashing, no problem, what card do you have? I'll even find which ones you can use if you want.
You can only raise the power limit, the voltage slider doesn't do anything unfortunately.
And yes i have a heatkiller iv block on it and custom water cooled. I had to cool it to 31.c to get these scores![]()
1440 score 167.6
min 143.2
3090
https://ibb.co/VTmDD85
1080 score 202.7
min 174.9
3090
https://ibb.co/k10yyzt
Nooooo don't let him beat me, I haven't got my 3080 yet! LolCould you post some GPU and CPU clockspeeds please.
You can do better than that mate, it's only 0.5 more than my 2080ti at 1440pSeeing as I was benchmarking my new 3080 on Forza anyway, I thought I'd contribute.
10600K @4800Mhz
3080 Inno3D X2 OC (Stock 1725/1188)
456.71 drivers
1920x1080
GPU 170.6
Min 146.0
https://imgur.com/PiCKgJN
2560x1440
GPU 138.5
Min 118.1
https://imgur.com/V2Ju4pz
3440x1440
GPU 122.8
Min 104.2
https://imgur.com/sLdAg7o
Enough for second against the 3090 in 1080 and 1440. But pulling a solid lead for ultrawide!
HAHA I know! How embarrassingYou can do better than that mate, it's only 0.5 more than my 2080ti at 1440p![]()
 That's a good score from you though. Shows how well the 2080ti's can overclock.Seeing as I was benchmarking my new 3080 on Forza anyway, I thought I'd contribute.
10600K @4800Mhz
456.71 drivers
1920x1080
GPU 170.6
Min 146.0
2560x1440
GPU 138.5
Min 118.1
3440x1440
GPU 122.8
Min 104.2
HAHA I know! How embarrassingThat's a good score from you though. Shows how well the 2080ti's can overclock.
I'll perhaps revisit this when I get the card on water and fiddle with clocks.
In the mean time I've just done a 4k run too
10600K @4800Mhz
456.71 drivers
3840x2160
GPU 92.4
Min 77.3
https://imgur.com/gFqdZVf
How strange. I can see them when in incognito mode. I'll try changing them to inline images instead.I can not see any of your images.
