- 16 Sep 2006
- Cornwall then Norfolk now
how are those linnmon desks thinking of getting 2x small ones to set up as an L desk i heard they can be wobbly ?Complete setup. Added some Astro's to the mix, real happy overall with my system and setup. (Also the headphones and dock are straight, I dunno why they look squint in the photo).
why do people buy those ikea worktops when you can get solid oak for around the same price ?
Likely for the conveience of not having to maintain it.why do people buy those ikea worktops when you can get solid oak for around the same price ?
worktop-express seems to be the go to place.Curious, where from?
Would be interested in this too as it's the only thing holding me back from getting one instead of the KarlbyFor all those with solid wood worktops, how often do you guys have to maintain them through methods such as oiling or varnishing?
Also have you added additonal underside support where you don't have drawers?
AFAIK, extra maintenance for counter tops with oil etc is only required if it's being used in a kitchen environment i.e. where it has to deal with water and foodstuffs. For use as a desk, just use whatever finish you want (e.g. varnish, poly) and that's it until/if it gets scratched or scuffed over years of use.
Indeed, Since I built my desk using an oak worktop which I used oil to seal it, I've only waxed it twice in 3 years. Still looks like new.
What wax do you use may I ask and did you have to prep the surface i.e. sanding etc?
Thanks! Guessing you've gone for the 30x40cm Ribba frame?A4 posters![]()
Thanks! Guessing you've gone for the 30x40cm Ribba frame?![]()
I'm currently looking at either a Karlby from IKEA or solid Oak from worktop-express. I'm just worried about maintaining it for the first 6 weeks like recommended.
