Would a smart bicycle light work on a powered wheelchair?
17 Dec 2004
Hi guys, I have managed to mount a speedo/distance counter and a powerful led torch to my wheelchair, and Im thinking to buy a rear bicycle light too... I have just come across these smart lights that turn on automatically and acts as a brake light. But would these be any good for a wheelchair that go a max speed of 4mph, but I would want it to come on as slow as 2mph?. Or would I be best getting one with a remote?
Why would you need one when you go a max speed of 4mph?
Braking from 4mph to 2 or zero is not going to make a blind bit of difference if a car or truck is coming up behind you on a country road, the speed difference is negligible. A permanent red light would be far more effective - its about being seen, NOT what you're doing. I see them on cyclists quite a lot - which I happen to appreciate as a car driver as I then notice they are there much further ahead than I would do normally.
I dont want one for the brake function, just to have a blinking one when Im on the roads and I need 1 with either a remote or a smart light.. I did come across this one with a remote, they are larger then the smart light and probably brighter too. I was also thinking about getting one that connects to a 24v battery and then somehow fixing it up to a on/off switch on a wire...
https://www.amazon.co.uk/Wireless-C...coding=UTF8&psc=1&refRID=B9JHDFH8SY4DN1E8XJCW
does your wheel chair not have lights and a number plate ?
I would fit cycle lights front and rear
Its a NHS chair so nothing fancy, but better then most. Its got the rubbish reflectors at the back as you can see, https://www.sunrisemedical.co.uk/q200r but I'll put the light between the reflectors. The holder that I printed out for my chair works well as a front light, its handy during the winter..
sorry to go slightly OT, but can you go on a road without lights on a mobility scooter? I thought they could only go on pavements (unless I've got that completely skating and there's some that can only go on roads:p). I'm just asking as I personally think bikes on country roads are bad enough due to the speed difference. I realise you probably don't have any other choice but it seems dangerous.
Wear high-vis (or at least have one item that is bright coloured/reflective) and have at least one constant light front and rear (while a blinking light can make it easier to catch the attention they aren't as good for other road users gauging position and speed/heading) - I can't tell you how many times I've had fortunately not too close but closer than ideal encounters with cyclists on country roads because they've blended in too well with the environment.
I have no idea about the and I havent heard of it even.. I have only been once along my main country road to the shop and it is a tad scary just because cars come passed so fast, but its a good ride, its about 1.5miles. But also sometimes I go dog walking across the fields and the roads are much quieter and cars go much slower.
Those types of bike lights use accelerometer sensors, I tried a cheap one and it found it unreliable and erratic so I would stick with a standard light.
I will probably get one with a remote and fix it to my torch holder somehow or print a separate stand and fix it on my chair somewhere.
[..] I will probably get one with a remote and fix it to my torch holder somehow or print a separate stand and fix it on my chair somewhere.
Maybe copy what you did with the front-facing lighting (since you have found that works well) and put a red filter on it?
You could also make passive use of the back of the chair - that would be a fairly large area for a high visibility section.
