Trying to find a good AIO (All in one) I got 25 CPU comparisons, now im confused!
17 Jun 2020
I have made the list below from the cpu benchmark websites.
The first number is the cpu score (higher is better from cpubenchmark.net) and the second number is rank table 1 being best 1247 being worst(from cpu.userbenchmark.com/)
I am looking for a all in one PC 24" or so and I run a lot of google pages, I dont run games really just theme point and betting sites, I want one which is cheap enough but fast booting and fast loading my pages, im getting confused as some of the cpus below score high on rank score and low on the rank table!
Any help would be great, the 2 I am looking at are I5-10210U & Ryzen 3500U this is whats confusing as the ryzen is 600 is more score but its nearly 300 less benchmark ranked, am I missing something? if you know of any other budget AIOs processors or computers then let me know.
CPU Benchmark
I3-7300T 4164 329
I3-8130U 3499 505
I3-8145U 3687 490
I3-9100T 5957 95
I5-3470 4670 247
I5-4430S 4685 283
I5-4590S 5157 219
I5-8500 9468 54
I5-8250U 6164 401
I5-8400T 7763 159
I5-9100T 5957 92
I5-9400T 7591 336
I5-9500 9710 29
I5-10210U 6503 309
I7-2600 5343 234
I7-3770S 6190 223
I7-4770S 6798 202
Ryzen 3 3200U 4186 784
Ryzen 5 2500U 6568 635
Ryzen 5 3400G 9416 214
Ryzen 5 3400GE 8565 not listed
Ryzen 5 3500U 7185 591
Ryzen 5 3550H 8140 480
Ryzen 7 2800H 7432 422
Man of Honour
22 Jun 2006
If you run a lot of Chrome browser tabs and games like that, I'd suggest RAM and a decent SSD will be more important to your user experience than the CPU. If you do need CPU power, cores would likely be more important than Ghz, so one of the new Ryzens could be a good fit and they're a big improvement on the last few gens of mobile CPUs.
Avoid dual cores like the plague and unless you're getting a great deal, I wouldn't want to buy an Intel prior to the 8th generation. The T and S models are often unnecessarily hobbled too, with not much difference to power consumption. Though this limitation may permit a smaller AIO.
Are you planning to use the onboard graphics?
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Don't use Userbenchmark, they have been banned from Reddit for being trolls with their ranking system, for example Ryzen CPU even when they are faster than Intel equivalents get push down the rankings just for being AMD and not Intel. They have even been banned from Intel's Sub-Reddit so this is just them being fanboys/
https://www.notebookcheck.net/UserB...breddit-due-to-drama-generation.461875.0.html
Userbenchmark literally said "Ryzen CPU's are performing too well" so they nerfed the results, that's like competition Marxism, "Your CPU's are too good so you get penalty points"
Watch this...
Try and find one with the newer Ryzen 4700U or 4600U, or maybe even the H variant if you can.
This, those CPU's are fantastic.
OP
17 Jun 2020
I would like to upgrade the graphics card if thats possible but not spend a lot I wanted better than the onboard which seems to be u630 or similar, is there a good one for less than £100?
Man of Honour
22 Jun 2006
The new Ryzens have way better onboard than the Intel HD 630 (the higher models have more performance), they'd probably be good enough for your needs. Upgrading the graphics card can be a problem with AIOs because they often have weak PSUs and reduced space in the case, so you may be limited to low profile graphics cards, assuming it's even possible to upgrade. Does depend on size though, some AIOs are super thin with no expansion whatsoever, while others are pretty big, comparable to an ITX or M-ATX build.
18 Oct 2002
West Midlands
Is there a all in one with this in that you know of?
Lenovo supposedly have an Ideacenter model with one in, replacing the 3500U revision with a 4600U and 4500U, but stock doesn't seem to be anywhere right now. HP might have something waiting in the wings as well, but I've not looked into it in great detail.
The thing to know about the Ryzen 4xxx based models is that they offer more cores, and better IPC, alongside far superior graphics to the IGP with most of the Core i3/i5 based models.
OP
17 Jun 2020
If you’ve got a 16GB SSD 3D Xpoint Intel Optane and a 8gb memory stick can you then not stick another memory card in there if it’s got 2 slots?
