Hi all, we're just considering a budget for a couple of big jobs on the house and I whilst I look around and before I get quotes, thought I might as well ask you lot as well.
Project 1 - Insulation
Our house leaks heat, pretty bad and unfortunately this isn't your average loft insulation job. The house is an old (but extended) detached 3 bed cottage, the 1st floor is in the eves and the loft is barely a crawl space. There is also a few single story parts with no loft access.
Therefore the way I feel it will go as to not re-do the interior is to remove all roof tiles for access and apply insulation boards and then replace the tiles.
Project 2 - Windows & Doors
We want to have 12 windows and 2 external doors (front door and rear french windows) replaced, with something prefereably decent.
One of the said windows is actually another set of french windows that we want to brick up and have a standard window put in.
Once this is all done the stone render will need to be put good and a full paint of the house.
I can add a picture later as a guide, but I have no idea how much to expect such jobs to be.
Any rough estimates?
edit: picture added. The other side is essentially the same, mirrored.
