I went from a Celeron 400 to a Duron 800 and never looked back. All my builds have been AMD since then.
That's a shame, you missed out on some great Inter processors over the years.
4700k to a 3900x will be a hilariously massive increase across the board. Absolutely everything will be significantly improved.
Exactly for gaming Intel is still king and for AMD workstation performance working the CPU 100% its night and day between them Intel is way behind AMD in architecture, value and efficiency from what benchmarks and reviews ive seen. Interesting reading the comments on the thread as Im looking at upgrading CPU/MB/GPU (And I also want more cores for work as working from home all the time now) at some point this year and I'm wondering whether to switch to AMD which I've never done before. I am mainly a gamer though so my worry is that I'll have to stay with Intel to have the best games performance but Intel pricing i think sucks compared to AMD and the overall the CPU package from AMD seems so much better at the moment.
Your cpu and gpu is smiliar to mine i dont think you need to upgrade anything bar the graphics card as you still have a very good cpu if all you care about is gaming and im not sure what your work is but do you plan on working and gaming at the same time?
From 4790K to 3950x, night and day difference, could not be happier!
5930k -> 3970x
cinebench r20 2349 -> 17490
That'll do![]()
4770k to 3700x and very happy.
I have a question though, when running a game my cpu frequency goes 2ghz then upto 4ghz it keeps changing a lot and also during Cinebench it only runs 2.6ghz any ideas? is there something I need to adjust in BIOS?
Cpuz says it runs 4.2ghz on desktop at times....been out the loop a while so this is new to me.
That's doesn't seem right, what's your score in Cinebench?
