hello
21 Dec 2019
Planet Thanet
welcome to the madhouse
ooops sorry forums
dont know the answer to that one unfortunately
but it took me quite a while before it didnt say you cant post here
really it ought to tell you these things in the important stickies
you probably wont know either in the beginning you have
a 15 posts a day limit to avoid new members bot spamming
21 Dec 2019
Planet Thanet
Fair enough. Makes sense. Cheers.
youre welcome mate
a little trick if you get into a longer post/thread is to edit your
previous reply that doesnt count towards your post count
if you are active the 15 post limit becomes very frustrating
drove me crazy lol
in the middle of helping people next minute you cant reply
more confusingly if you hit the 15 limit its not a simple reset at midnight
its a rolling reset
ie 24 hours from the time of each previous post
so for example if you just edit your previous reply you wont lose 1 post from your count
got an atrocious memory lol so forgot how long the 15 post thing lasts for
OP
10 Jun 2020
Scotland
15 is less than I usually post a day on average so all good.
Part of the reason I signed up, is I was kind of hoping to talk about covid tbh, as other forums I'm on are pretty toxic in that regard.... so I'm all for moderation on this topic.
But is read only disabled too? I can't see any covid posts at all?
ETA hit my limit, so using your edit trick!
It's not there. Perhaps I need to login with Tor.
Oh well, probably do me good to think about something else for a bit. Thanks for your help though
21 Dec 2019
Planet Thanet
theres a whole sub forum on covid19 its probably the busiest part of the whole forums
you should be able to see that i think-will see if can give you a link
give me a minute
21 Dec 2019
Planet Thanet
yeah the edit thing works fine
though doesnt notify you replied but if its a running post i know to
just check it every now and then :)
surprised you cant see the covid19 one though would have expected
that to be open to all members
not sure tor or a vpn will work but can try anyway
