Thanks Mr. Bell![]()
  It was hard to fit the text in with your name.HELLO!
Not been in here for ages and ages...
I've attached a few examples. It is the logo of a record label.
A rotating one would be wonderful but depends how bored someone is! But one of the favs below would be wonderful.
http://after.life/wallpapers/
Top row, 4,5,6
Second row 5
  Any changes let me know.
	@SideWinder
Do you just want a rotating sig with these 4 images? They are static images but a bit of magic on the server side that makes it rotate.
EDIT: Here you are, rotating as well but you will need to use this link otherwise it won't rotate. I have hosted it for you to make the magic happen.Any changes let me know.
https://sigs.ocukrogues.ml/sidewinder.jpg
Only small favour to ask, could the white border be removed?
So cool!
Thank you so much!!
@mrbell1984 would you like to host mine for a £? Or if you send me what you've put together I'll host it.
@Marky
Tell me if you want anything changing in these or if they are no good too you.It was hard to fit the text in with your name.
Thanks so much for your effort dude! I love them
The first is my fav - Could you maybe try a different font for my username?
I don’t mind if the text is smaller either - might even look good if it looks like it’s been scratched into the train above the window
Thanks again mate, stellar effort![]()
Have you got a certain font you would like me too use?
How about this?
I like that better actually, but I can’t really see the Y very well - Is there any way to make it look like the scratch on the window is the Y?
I’ve not got a great creative mind, so I don’t have a clue regards to fonts![]()
  Bit more clear.@mrbell1984 would you like to host mine for a £? Or if you send me what you've put together I'll host it.
