I've decided to buy these -
https://originfitness.com/origin-40mm-high-impact-tile-0-5-x-1m-x-40mm
Double thickness, might have more luck![]()
Any thicker and you'll have to class them as rack pulls![]()
- they aren't really designed for the 'portable' squat rack, but they'll be low down and I place 25kg weight plates on each corner of the base anyway. I also haven't needed a spotter arm in 2-3 years, but nice to have.See now I have questions about spotter bars. For squats I get it - you can dump the weight safely. I'm starting to struggle on bench press though but putting spotter bars in means I can't get full ROM? Seems counter productive but then again I do train alone - what's the best course of action?
I set my spotter so that if I exhale everything, It hits the spotter.
If I've got a big chest of air, braced, I touch my chest with no hitting of the spotter
Ah! Of course there's a thread for this, was just about to make one of my own
Like many others the wife and I have decided to tidy up the garage and convert the back 2/3rds of it into a home gym. Early days in the planning yet and I already know what I want equipment-wise (when it someday comes back in stock; kind of thinking I might aim for Black Friday sales at this rate! Or if there's an influx of people selling the stuff they bought when lockdown started once gyms open I may look around)...
Anyway what I am wondering about and maybe people will have experience with is this; the first thing I want to do is get the space setup a bit, and try and take the edge off of the temperature swings in there - intending to:
What I'm wondering about though is that the garage door has some vents in it - how important is it that I leave those uncovered? By and large the garage isn't particularly drafty - it's only ~5 years old, pitched roof in good condition, not excessive gaps around the edges or bottom of the door. So I'm a bit worried that if I take away the ventilation in the door I might turn it into a condensation hotbox? Particularly as there's also a tumble-dryer in there. Can anyone comment if my concern is unfounded? I could cut the Celotex in a way that doesn't block up the vents if so (and follow up question - if I do that will it defeat the point of trying to insulate the door altogether?
- Insulate the door of the garage, probably just use adhesive foam to glue some celotex panels onto it
- Get some horse stall mats / gym mats and fit them down on the floor
- Get some acrylic mirror panels for some of the walls
- Possibly buy a small portable heater and a chrome fan
Any other tips or advice? Equipment-wise if anyone cares I already know I'm intending to go with a cage, bench, lat/cable machine and a spin bike for cardio. Won't need anything more than that... Cheers in advance!
How big is the garage ? If you are planning to only use 2/3rds, you might have to squeeze things in and would suggest maybe getting a 6ft Oly bar that still fits a rack - I have that and a 7ft, and the longer bar is just a bit tight in there.
A few things I did -
Added some battens and then a few sheets of plyboard over the metal garage door (the one you would drive through) - didn't insulate it any more than that but it stops any drafts
Added a draft excluder brush to the bottom of the (wooden) garage door (the one to walk into the garage) to stop any drafts
Added gym mats from Ark and cut to size where needed (I painted the floor first to stop dust ups)
Have an oil filled radiator on a timer switch for the winter and a little fan from Amazon for summer. I need a better heater for this winter, having trained out there all last winter.
Not had any problems with condensation as yet - up until around April, had a tumble drier in there and just kept the door open a bit - now thats gone and its 100% gym space !
Can anyone recommend somewhere to buy olympic weights & 7 foot barbell? Seems like powerhouse / fitness superstore may not have anything back in stock until july/august! Although I'll assume if that's the case then there's no chance of getting them anywhere in the UK til around the same dates.
A very LIMITED amount of Barbells & Bumpers will become available to order this coming FRIDAY 19TH JUNE.
Don't want to miss out? Make sure you sign up to be notified at the exact moment they become available to order, via the product pages.
Please Note: Subject to stock, these products may or may not be available to purchase separately. They may be solely designated to Bar & Bumper Packages.
Where's your power rack from?
Oh, you know... Aldi
https://www.aldi.co.uk/wellactive-multipurpose-power-rack/p/000000396717200
did u buy these direct? aren't they like £1k for a plate set?
