Remove all drivers or fresh install of Win10?
19 Apr 2012
I had a laptop which failed at the start of the year but it had a fresh install of windows 10. This was an intel CPU and GTX GPU laptop.
I've now ordered a new laptop which is AMD CPU and a RTX GPU. When I come to fit the hard drive to my new laptop, Would I be best to wipe clean and start from scratch or could I just remove all drivers and install the AMD and chipset drivers?
I know Win10 isn't much of a push to install these days but was more thinking of other stuff that I had setup on the drive.
Edit: To try make more sense of what I originally wrote!!
I'm a bit confused, when you come to fit to your newer laptop, why do you need to remove all drivers?
Freshly installed is always best, however
you would have to reinstall them and change any default Windows 10 settings. Windows 10 handles hardware changes pretty well, and often installs most things automatically. That said, if the hardware changes are major and you've had the OS install on quite a while , a clean install (or reset) is usually a good idea.
Surely all the drivers would be installed for WiFi, Ethernet, GPU, Chipset etc etc of the old laptop?
The windows install was only a couple of months old really with mostly games installed installed and a few programs like throttlestop. Maybe I should just wipe and fresh start for the sake of possible issues. At least I'll know it is clean and totally fresh.
I would order an external drive if you don't already have one, and then put the old drive in. Windows 10 handles new hardware pretty well then back all your stuff up..then put a clean install of Windows 10 on. After that then re-put your documents/files back. More effort but I think that would be better in the long run and just stops any potential problems later, also your documents and files will be backed up.
Yeah maybe a good idea just doing that! I'll go down that route I think. Thanks.
Although you could probably use Macrium Reflect and a USB caddy to clone the drive to your new laptop's M.2 drive, I'd probably just bite the bullet and do a clean installation. Even on new laptops I prefer to do a clean installation, as they seem to come with bloat from the manufacturer by default.
Yep sensible; clean installation. Have a USB caddy and then get off all your documents and files once installed, and then you have your original external hard drive to have as back up for docs/files too.
Was hoping it would be one M2 and one
2.5
Guess that's progress for you lol
Well, From what I've been hearing was that the AMD chipset didn't support a SATA HDD. I assume they meant for that motherboard but I have noticed the likes of Asus, Dell, and HP only show M2 slots also where as I think the Legion had both.
