Dac/amp - usb needed
Caporegime
13 Jan 2010
Llaneirwg
Want a USB dac/amp
Want to be able to be able to power 2.0/2.1 and when headphones are plugged in it auto switches to those.
Any options other than creative x7?
I use an SMSL AD18, really happy with it. You can leave your headphones plugged in and just quickly switch outputs manually which is quite convenient.
Ill have a look at both of these now
depends how much you want to spend and which headphones you use i'd say, no point chucking loads of power or money at low ohm headphones
take a look at "audio science review ,audio electronics reviews and measurements index" third google result down its the one where you can set all the product filters
I think you're better off buying the best dedicated headphone amp you can and best separate dac for the budget not a fan of jack of all trade products theres a few decent budget headphone amps and dacs floating around at the mo, ifi zen, creative xg6, the smsl and topping stuff.
Sounds maybe like an external soundcard would suit more if you're running 2.1 pc speakers.I wouldn't throw over £100 at it if you don't use high end headphones.
i'd rather spend a little more and get the topping dx3 pro than ifi zen
audio science review has panned the ifi zen dac he's got really poor readings from it
schiit heresy and magni dac stack i'd say
Headphones are denon d2000
And haven't got speakers.. Yet
those are classic great headphones, i'd use audio science to make your choice some love the ifi zen dac but measurements don't lie
schiit heresy and magni probably the best up to a certain price still
z reviews on youtube reviews all dacs and headphone amps worth a watch to decide
They are great.
They are so used the head band and ear muffs are perishing. Not sure how to fix the head band.
Tempted to get an av receiver to be honest
Don't hold too much importance in measurements, they only tell a part of the story. I'm neither a subjectivist nor an objectivist - I appreciate meaningful measurements but also trust my ears.
Amir at audio science review has a hard on for Topping, he gives everything they GIVE him a glowing review and the distortion measurements are totally meaningless as they are well below the level of human hearing.
Zeos (Z Reviews) is a decent entertainer but a lousy reviewer - he also gets given a lot of Topping and SMSL (same company) gear.
Personally I would go with either the ifi Zen DAC, which sounds good, has good features, such as MQA should you wish to listen to Tidal and a very usable bass boost button. It's not the most powerful amp out there but will be plenty for the Denon D2000.
If you do want lots of power for (future) harder to drive headphones, then the Schiit stack of Modi 3 (DAC) and either Magni 3+ (amp) or Heresy (amp) can be yours for just over £200. The difference between the Magni 3+ and the Heresy is that the former uses discrete components in it's circuitry while the Heresy uses op-amps (chips). The Heresy was built to see if an amp designed and built purely to measure well could also sound good and it turned out to sound so good Schiit put it into production alongside the Magni 3+. As for which sounds best, well that's subjective as it's totally down to people's preferences but both seem to be selling well.
They are great.
wont be any good for headphones they rarely have headphone amps
throw it in the trash and buy something else - it will probably be cheaper than sending it back to China :D
wheres the ifi zen made ?
I had a Topping VX1, it lasted about three years but I think one of the relays failed. Would have loved to get it repaired but I enquired with a few electronics/hi-fi repairs places and it just didn't seem worth the cost, hence why I got the SMSL AD18.
To be hones , this seems like the easiest option. One device and it does both. Seems to have fairly good reviews
