Can I cut this wire...
1 Nov 2002
Sussex
I’m no electrician. I need to shorten this telephone cable (obviously).
Can I just cut through it to do so? Some of the wires in the box aren’t even connected to anything. Anyone got any ideas?
Don’t want to cut it and give myself a new hair do.
10 Jan 2012
UK
I'd just pull it out of the box put some electrical tape on the end for good measure, push it through the hole and plaster over hole.
23 Nov 2019
unscrew the cover, use a voltmere and ammeter on the terminals and see what it detects. I bet it's low enough you'd be fine to cut it without issue.
23 Nov 2019
I'd just pull it out of the box put some electrical tape on the end for good measure, push it through the hole and plaster over hole XD
this isn't a bad suggestion. It's a pain lengthening cable at a later date if you can just push it into the wall or floor void.
27 Dec 2009
Err, what's it connected to at the other end?
rare cuts the wire and sighs with relief as nothing explodes.
Meanwhile, in the hospital next door...
