- 27 Jul 2005
- The Orion Spur
After a few failed cheap (£80) PU leather gaming chairs, I decided to go secondhand and try and grab myself a 'proper' office chair, my old gaming chairs barely lasted a couple of years a piece, mainly due to excessive peeling and the foam/padding flattening, luckily I have a very good secondhand office furniture warehouse at my local industrial estate.
I ended up grabbing a leather Boss Design Sona Task Chair for £120, fully specced out these things fetch around £900 new! I can see why people pay for premium office chairs now, solid build quality, nice chunky aluminium frame, foam padding is still firm even though this particular chair is a good few years old, and best of all this thing is so adjustable it's insane, you can raise/lower the backrest, the arms can raise/lower, the rests themselves can move in all directions, the seat base can move forward and back, and can also be tilted forward 4 degrees.
With all the adjustments you really feel you can tailor this chair to your body, and most importantly your back, when you sit on this chair you can feel your back being pushed into the right position, that may sound uncomfortable at first, but it's a satisfying feeling, my old gaming chairs had very poor lumber support and you ended up slouching in them, the back support on this chair rests on your lower back, so when you lean back you feel your back straighten.
Here's a link to the chair if you are interested in the specs,
https://www.bossdesign.com/product-list/sona/
I've made this post mainly because if like me you are working with a lower budget it might be worth grabbing a secondhand chair that might last longer than a cheaper new chair, and also have better build quality and adjustments, these for example can be grabbed (albeit lower specced) on 2NDHND for only £115, if your looking for a solid office chair for around that price I would definitely recommend this one, or at least try dipping your toe in the secondhand market.
