- 20 Oct 2002
- Derby
Has anyone experienced this issue at all?
Recently a friend of mine had a problem with his daughters old pc and it appeared as if the GPU had given up the ghost (I think it was an old 8800GT) So rather than getting a graphics card to fit into her system i said why not upgrade yours and then fit your old one in her machine? He had a system that was working fine 2700K, 16Gb, Gigabyte Z77-D3H motherboard, GTX570 so he purchased a 1660 but for some reason it would not post/display. Do after a bit of trying things I had a look and thought it may just have been a BIOS issue so I managed to get that updated and it seemed ok. But then he was getting random issues again with not displaying so I looked again. It appears as if using a PCIe 3.0 GPU in the system is causing the bios to not display via either the onboard or the GPU. I tested with the 1660, a 960 and also a Quadro P400 and all did the exact same thing until I installed a gtx580 and that all worked fine. The only difference is that the newer cards are all PCIe gen 3.0 and the 580 is 2.0.
So I thought it could be down to the CPU as the 2700K only officially supports PCIe gen 2.0 so I installed a 3570K and that did the exact same thing. So currently he has to buy a new CPU/Motherboard/Memory to get back up and running.
The strange thing is that I have the exact same issue with a little emulator system I am building for a friend with a Asus P8H61-I LX R2.0/RM/SI board I have (Running a 2600, 8gb) I cannot get the GTX960 to display in the system at all. At first i thought this could be a locked down SI version of the bios that RM had to stop people playing with their systems but I have spoken to my contact at Asus and that doesn't appear to be the case. Its old but does support Ivybridge and PCIe 3.0 graphics cards but I am not able to get any of them to work. Its a really odd situation but as the components are so old its not something that's covered under support so really at the mercy of doing google searches on forums for possible help.
Any help or advice would be appreciated.
