- 17 Jun 2020
Again, it is not loud, but it is distinct. Here are couple of screenshots, maybe that will explain it better, taken in noisy environment (AC running full blast), green lines are instantaneous so they move a lot, the magenta is averaged :Ya, very odd. Only way I can hear my fan is if I put my ear up to the back of the monitor and I'm a pilot that gets hearing tests done every year with great results. I also keep my room pretty cool, ~19C so maybe that also keeps the fan RPM down.
Noise measured at the top vent:
Noise measured at arms length, where I sit:
Monitor off, same position as above:
That spike at 6k in the middle picture is what causing me headaches. Objectively, this monitor is not loud at all, but it is annoying as hell. Like a fly in a bedroom when you're trying to sleep.It is not like I'm imagining things here, it is clearly visible in the graph.
Since you're a pilot, do they ever give you some kind of a chart showing how you respond to different frequencies, or is this just pass/fail type of test? Could you open the service menu and check what is your die temperature?
I couldn't turn it off on the GL; the best I could do is reduce it to a smaller, floating status box that traveled around the borders.
