- 29 Sep 2010
So, I’m doing a pretty niche build, more info will follow once it’s complete (not far off) but I’m working in a small case with 3 radiators.
Now on the 240 radiator, then 2 x 120 fans are directly on the panel of the case, so it goes |case|fans|rad|gpu.
So I can either;
A. Push in cold air from the outside, onto the rad, but the air has about 1 maybe 2mm clearance before touching the gpu. The top does have a vent so I guess the air would still naturally exhaust out of that?
B. Exhaust the hot air off the rad and out the case, this is how I have it currently as it’s installed (waiting on fittings to complete) with the air space in the fins, my logic is that this would be more efficient to just dump that air out of the panel of the case.
Thoughts?
So I can either;
Thoughts?
