Hi all, I found this thread when searching for VM throttling my connection when downloading torrents. I would appreciate any help or insight you guys can provide on the following please, and whilst I am by no means a novice, I do not consider myself an expert or advanced in anyway on this topic.
I have a 350mbit Virgin Media broadband cable connection through their 3.0 hub in modem mode and then connected directly to my TP-Link Archer C9 cable router.
This has been my setup for the last 2 years and have not had any issues with speed capping, slow down or any dropped connections ever.
That is until recently, where I have now noticed if I attempt to download ANY torrent, my connection is throttled to less than 1% of my speed, in actual fact when I do a speed test with the speedtest app on my phone, it shows as between 512kbps and 1mbps bandwidth.
However, as soon as I stop the torrent, within 10 seconds my speed returns to normal and have no issues. I first thought my router had broke in some way, but having rebooted it, checked I was using the latest firmware which I was, and after monitoring the CPU and memory usage of the router whilst performing this test, the router is not stressed in anyway, so I do not believe my router is to blame.
I have been using qBittorrent for a long time, with no setting change, but just to be sure, I reduced the number of global maximum connections to just 150 from the default 500, which had no effect. This was also just trying to download a single torrent, with around 10 seeds and a few leeching peers.
Today after being very frustrated at this, I decided to try using a VPN, just to see what would happen. Guess what, speed remains high when downloading torrents, no slow down, no throttling, perfect as it has always been.
Now am I missing something here, but does this not suggest VM are currently severley throttling my connection if they detect a torrent being downloaded? Which they say they do not do?
Any ideas or help would be much appreciated.
Thank you.
Thank you.
