New gaming pc. Will this work?
7 Jul 2020
hi guys just put together this gaming pc. Will this work?
Case
COOLERMASTER MASTERBOX TD500 MESH RGB GAMING CASE
Processor (CPU)
AMD Ryzen 9 3900X 12 Core CPU (3.8GHz-4.6GHz/70MB CACHE/AM4)
Motherboard
ASUS® TUF X570-PLUS GAMING (USB 3.2 Gen 2, PCIe 4.0, CrossFireX) - ARGB Ready!
Memory (RAM)
16GB Corsair VENGEANCE DDR4 3600MHz (2 x 8GB)
Graphics Card
8GB NVIDIA GEFORCE RTX 2070 SUPER - HDMI, 3x DP GeForce - RTX VR Ready!
1st Storage Drive
2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE
1st M.2 SSD Drive
500GB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3200MB/W)
Power Supply
CORSAIR 750W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Power Cable
1 x 1 Metre UK Power Cable (Kettle Lead)
Processor Cooling
Corsair H115i RGB PLATINUM Hydro Series High Performance CPU Cooler
Thermal Paste
STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
LED Lighting
2x 50cm RGB LED Strip
Sound Card
ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking
WIRELESS INTEL® Wi-Fi 6 AX200 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
USB/Thunderbolt Options
MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Operating System
Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001]
30 Jul 2007
Lincolnshire
Have you tried pressing the Power button? :p
Jokes aside, of course it will 'work' - but is it over priced for just a gaming PC? Most definitely considering it's pre-built, has a 3900X, a Samsung Evo Plus M.2 and a pricey W10 license ;)
If it's just for gaming - 3600 CPU would be ample, 3700X at a push if you want to future proof and maybe do more with it later.
How much is that costing / what's your budget? Have you thought about building your own PC?
12 Sep 2005
Grundisburgh
What? Too expensive for a gaming PC! The most expensive pc's I've seen are gaming PC's .
The bigger question is why isn't that a spec from OCUK?
Andi.
30 Jul 2007
Lincolnshire
@andicole0 3900X overkill. Has moneyz to burn? Pour into GPU. :D
I did notice it was from a certain retailer that shall not be named... I find it ironic that people buy from other retailers (which is fine), but then swarm the OcUK forum for advice before hitting buy. :o
30 Jul 2007
Lincolnshire
Ah right, well yeah of course it will very nicely!
It's just a bit imbalanced for the money - having a 3900X and 2070S for gaming. I'd of stuck with a 3600 (or 3700X) and put more money into a better GPU like the 2080 Super for more FPS, if you was happy splurging that money on a nice gaming rig :p
That said the 2070S is still a fantastic GPU, I have one myself :D
