Interested in the tech side of this. How come a PWM hub plugged into the same 1amp limited fan header (with f.ex. 2x fans rated 0.5amp that can be drawing 2.5amp) doesn't burn it, but individual fans do?
I just did, but didn't find anything
Anyway, did some more homework and inserting link to fan related page from mobo manual. Turns out there's like 5 ordinary fan headers and even 1 high-amp one supporting up to 3amp !! Don't see the difference between CPU_FAN and CHA_FAN though. In such a scenario, could I just plug all of my 6 case fans into either the thermalT/Fake into the 3amp H_AMP header ? At startup they would max out at 2.22 amp, there's a lot of leverage left here. The GPU ones I could then plug in the Gelid splitter in the ordinary 1amp header ... Or even just use an ordinary PWM y splitter on the Gelid adapter I linked to and plug this into an ordinary 1amp header ? I mean these two GPU fans will never get over 1amp anyway? In this case they'd be drawing power from the mobo and not SATA.
https://ibb.co/3Ct6vZs
