Side question has anyone ever experiences an issue with the hub 3.0 where it seems to lose connection and takes about 3-5 mins to restablish its connection at roughly the same time every day?
I upgrade from the 2.0 to 3.0 Hub as the wifi network would disappear on the 2.0 suddenly and ever since upgrading to the 3.0 Hub it drops the connection at 12:15-12:30 every single night and has done for over a month and aside from this restart every night the connection is solid. Virgin claim there is nothing wrong and are sending an engineer out but to be honest its a waste of time in my opinion as their forums are littered with basically the exact same complaint but no-one has ever provided an answer. Plus ive only had this issue since upgrading to the 3.0 Hub so im convinced the 3.0 hub is either a pile of **** or its a setting on their end and they have no idea what it is.
They are apparently taking orders if you already have ADSL/FTTC with them and you phone it inFTTP with TalkTalk? I thought they weren't releasing any FTTP products until mid-July? That's a lovely low-level ping.
I've just served my 30days with VM, looking to switch to FTTP but only BT offering it at the moment so holding out to see if TT do start offering or whether I just go direct to BT.
Is that an improvement in ping @Rainmaker or the same as before?
Be interesting to see a thinkbroadband graph on your line with DOCSIS 3.1.
I kept the same IP as I use a stand-alone x86 router running OpenBSD so my graph will continue on.
Yeah, 3.1 is on the downstream only, not sure Virgin even have plans for symmetrical connections.
No probs, try phoning if you want to get a better price. I remember I got a few quotes last year but it was only £3-5 off for FTTP products. However that was back when only they could supply FTTP.Cheers @moogle ... I think I'm just going to go with BT for now. 150 for £39.99, I could go for the 900mbit but I genuinely don't use the speed, my 350 with VM is already wasted as it is.
This is why they need to get on top of the latency issues and dropouts. I know Virgin have project lightning but Openreach are covering millions of properties a year with FTTP, giving providers not only better speeds, latency and uptime than Virgin but also better pricing.
