- 8 Dec 2002
- North Yorkshire
He doesn't want to catch Covid from 5G
Short of building your entire flat from scratch around the principles of a Faraday cage and/or having really thick walls you aren't going to accomplish it.
Many years back there was a thread, possibly on Reddit, where people had moved into houses and found stuff like that setup and/or rooms where the/a previous owner had rebuilt them as Faraday cages.
EDIT: Similar post here https://forums.overclockers.co.uk/threads/new-house-has-faraday-cage-in-the-loft-room.18614135/ I thought I'd seen something here as well.
Cover your whole house in tin foil. That should do it.
I went to look a property last month, a few doors down there was a house that had every window and door covered in tin foil. I'd like to think that it was just a cannabis farm but I suspect it was a tinfoil hat lunatic.
We didn't make an offer on the property.
I dont think OP is coming back...![]()
Must have achieved his goal and now can't get online.
The only sane reason for doing that would be if someone wanted to work on communications equipment and ensure that it couldn’t radiate a signal beyond the room. Cloning/wiping stolen mobile phones or examining something the alphabet agencies really don’t won’t you to have and such like.
Used the RF tents before in my previous telecoms life to block out the local cellular network while injection a simulated network for roaming testing. Nowhere near as effective as the purpose built shielded chambers, but much cheaper and don’t cause floor loading issues.
People get crazy just at the mention of RF/EMC test equipment sharing a building with them. I had a perfectly sensible and normally reasonable senior manager at Apple start to have a meltdown because she thought I was going to give everyone cancer by having several RF test systems installed in the building. Because I worked on new stuff, no-one outside the my team was allowed inside our area which made them all suspicious.
I had to patiently explain that I was only testing iThings like the ones everybody in the building spent hours using everyday at the same signal levels they all used. The only reason I have these large metal chambers is so that the stuff I’m testing doesn’t register on the local EE cell and that everyone nearby doesn’t register on my test equipment.
Presumably, you create your own cell within the chamber for test purposes.How do you test a cellular device in a chamber when it relies on connection to a network for it to do its thing??
I wonder how many they've actually sold.
Just don't like being mocked on an online forum. It's really dented my confidence
Where were you mocked? I can see lots of digs at 5G conspiracy theories, I can't see any mocking of you as an individual, not in the posts I read anyway.Just don't like being mocked on an online forum. It's really dented my confidence
