The aforementioned "Stage X item" just strikes me as really stupid. Who defined the stages?
"Rare spec" is one that annoys me. It will nearly always be applied to the only spec that that particular model came in. Such as "Jaguar S-Type R - Rare spec". No, normal spec.
The thing is, to me; fully loaded means that it has every single option available added. Maybe my understanding of the word is different to anyone else'd but I bet there are very few - if any - fully loaded cars in the UK according to my definition.
And the oil, tyre pressures and anything else hasn’t been checked or fixed and the interior is likely covered in scratches. Most of the women I know don’t look after their car half as much as the blokes.
Yeah, all the toys, optioned up, fully loaded etc. etc. always seem to apply to base spec cars. "320d ED. electric windows, central locking, fully loaded". I'd be interested to see an advert with "partially loaded" in the description.
As someone slowly building a car....
"Aren't you finished yet?"
In my head "Are you some sort of ****head? Do you think I'd be lying under it on the drive with no body work trying to fit the brake lines if it was? More to the point, would you drive this on the road?"
Out loud "Haha, no, one day though....."
What they mean is "hurry up and finish this heap of crap, having a half built car on your drive is making the neighbourhood look a bit déclassé"![]()
"Its just a car!"
Usually said by the person that just damaged yours![]()
