- 8 Dec 2002
- North Yorkshire
I’d just wait for nord to come back on offer they always have offers.
Can anyone share their experience of TorGuard?
I did find another code to re-enable the 3 year code
@visiblemanBESTVPN is the code
So I found a this site by someone called Top Sparks https://www.vpntierlist.com/vpn-tier-list/
He also has videos on YouTube. He seems to know what he's talking about, and recommends TorGuard as the best overall VPN.
Using his code, 2 years costs £50.
Nord still a good VPN service to go for? Looking for multi-device (couple of PCs and an iPhone).
It really depends on what you define as good and your particular needs? Also BF is looming, expect the usual slew of cheap deals on VPN and other online services.
@~cw : Out of interest; Have Nord started offering a load balancing domain you can hit from 3rd party application (not through their GUI.. so for example from my Synology NAS) to say uk.nordvpn.com?? When I last used them I had to manually use one of their many servers in a particular country (for example uk1.nordvpn.com, or uk2.nordvpn.com) - meaning if one of their UK servers where unavailable or running slow, I would manually have to change the VPN to point to one of the other VPN nodes.. which was a non-starter.
With my current VPN provider I can just point to uk.xxx.com, and they redirect the traffic to whatever local server I need to go to, based on usage, etc.
Nope. However this Python3 script does exist: https://github.com/jotyGill/openpyn-nordvpn
I asked Nord about a load-balanced / "pool" endpoint address which you could use to easily connect by country and category (e.g. uk-p2p.nordvpn.com, uk-double.nordvpn.com, uk-tor.nordvpn.com etc). They have apparently sent the suggestion to their dev team. So who knows if/when it might happen... It's a bit of a bugbear of mine as well. Torguard uses a cruder method of multiple A records for each of their hostnames to sort of accomplish this, mostly pot luck but it does exist.
Nord works with iPlayer, just checked now and it's streaming fine (connected to UK with NordLynx protocol).
Frustratingly, the desktop app doesn't have any split tunneling features built in (unlike competitors like Torguard or PIA) but Windows 10's VPN client supports SSTP or IKEv2 so you could use that with Nord and enable split tunneling at the Windows VPN adapter level. It's a little unsophisticated compared to something like PIA's offering. You could also use Nord via SOCKS proxy for specific apps. The mobile app can split tunnel, and Nord claim their browser extensions split tunnel - by virtue of their scope I suppose it's technically true.
Another alternative might be using OpenVPN client on your machine with a NordVPN server config (https://support.nordvpn.com/Connect...-manual-connection-on-Windows-7-and-above.htm), then either handcrafting the config to use route-nopull then 'route a.b.c.d' for specific web IPs, or trying "allow-pull-fqdn" which apparently should be able to resolve IPs from a FQDN record? Other discussions mention using pull-filter declarations in the .ovpn config (https://forums.openvpn.net/viewtopic.php?t=30951&p=94388).
I have set up OpenVPN client with NordVPN .ovpn server configs on various devices, but I confess I've not tried configuring split tunneling like this as I don't VPN 24/7. You've got me interested now though![]()
