Not really hard to work out the max performance of the RTX 3080 TI, considering the 400w TDP of the already released Ampere A100 SXM4. Should be around 25% lower if the TDP is 300w so that would be approx:
Pixel rate:
169.2 GPixel/s
Texture Rate:
456.8 GTexel/s
14.6 TFLOPS
A100 SXM4 Specs:
https://www.techpowerup.com/gpu-specs/a100-sxm4.c3506
If we assume a similar boost clock to the RTX 2080 TI (1545 MHz), the figures would be:
Pixel rate:
120 ROPs x 1545mhz = 185.4 GPixel/s
Texture Rate:
324 TMUs x 1545mhz = 500.5 GTexel/s
5184 Shading Units x 1545mhz (x2) = 16.018 TFs (maybe 17TFs if GPU clock frequency is higher than the RTX 2080 TI)
So, if that ends up being correct, the raw computing performance (TFLOPS) of the RTX 3080 TI will only be about 19% higher than the RTX 2080 TI, and 31% higher than the Xbox X Series GPU.
The rumours of the RTX 3080 TI being a 20/21 TF GPU are almost certainly complete crap, Nvidia couldn't reach that with their ultra expensive Tesla / Ampere based GPU. It's not that surprisingly really, the Titan RTX and previous Tesla GPU were only 13-18% faster than the RTX 2080 TI overall, link here: https://www.techpowerup.com/gpu-specs/titan-rtx.c3311
EDIT - The PCI version of the Ampere A100 SXM4 has a lower TDP of 250w, but during a " sustained load will provide 10 to 50% lower performance than SXM4 based variant".
https://videocardz.com/newz/nvidia-announces-a100-pcie-accelerator
Let me know if you agree / disagree and why
Pixel rate:
169.2 GPixel/s
Texture Rate:
456.8 GTexel/s
14.6 TFLOPS
A100 SXM4 Specs:
Pixel rate:
Texture Rate:
