- 10 Oct 2006
I’d be asking if they have replaced the turbo oil feed pipe.
I'd probably take it elsewhere.
Any pay again?
Well, let's see what they say this time but you said your self you've lost confidence. It'll surely get to a point where you cut your losses and go elsewhere... I'd say somewhere trustworthy but I'm unsure if such a place exists.
This is exactly why I started doing things myself.
These got recommend. But looking at reviews, I've had the same treatment. Job not done right, no updates, very long waiting times.
Wish I'd of read them first. But then again, I can't remember the last time I left a good review for somewhere, so places can't always be judged off that
well it could be oil contamination in the exhaust burning through ,seen this over the years on a couple of vehicles that had turbo problems where they dumped a majority of oil into the exhaust. usually took a few days to burn off and stop smoking , of course with the audi i guess the possibility of cat getting contaminated would lead me to ask them to drop the exhaust and clean it out. assuming that the car is running correctly except for the smoke.
do you know how they fixed the turbo? Repair, refurb, replace (new or refurb)? for a working turbo to fail so quickly it sounds like no oil is getting to it - that should be easy enough to diagnose once removed though.
They sent it off to be refurbed. From what I've been told you can't just change the cartridge and it needs balancing?
They said it's getting oil and they have no idea why it's failing. Not spoken to them yet since it's been back. Going to ring in the morning.
I think when you speak to the 'gaffer' - you should be saying that you have reason to believe the issues are due to sub standard work and you're going to seek a second opinion.
Sounds like they have absolutely no idea what they are doing, or talking about.
Ask them how a knock causes an engine to smoke... To my mind they are two completely disconnected symptoms.
Have they dropped the sump and cleaned the oil pick up, this is what normally kills the turbo when partly blocked and restricts oil flow.
