- 9 Dec 2009
- Bristol
Looking at a 2012 mk3.5 PRHT Venture over the weekend and had a thorough rummage through the MX5OC and MX5Nutz forums at buying guides. Car seems decent, reasonably low mileage for age and all checks out on the VCheck report but other than whats on the MX5 forums, has anyone got any additional things i should look out for?
Also read that the oil level should be kept at Max (or just over) on mk3's - how much of an issue is it if it's below? Just wondering if i do a runner if that's the case.
PRHT. It should smoothly go up or down in about 12 seconds. If it seems like it's struggling then something is wrong and it'll potentially cost a bomb to fix.
Rust rust rust. If it's in good condition underneath it's either been undersealed and the owner stayed on top of this or the car was only taken out in good weather. If it's rust free and not undersealed get it done! Rear arches can suffer too, and underside of bootlid by the numberplate lights.
Oil level does need to be kept at Max and if a tiny bit under I wouldn't be too bothered but if really low I'd suspect neglect.
Having said all that they're ultra reliable and an absolute hoot to drive!
Good luck.
