By the end of next week I should have all components to start building my new rig, but as it's about 8 years ago since I've put together my current pc I thought I'd better ask/check a few things as I don't want to mess it up.
I came on here a few weeks asking if it was worth upgrading my CPU or GPU but after listening to some advice I've decided to upgrade everything, including a new monitor, and I've now bought the following :
- Gigabyte X570 AORUS ELITE
- AMD RYZEN 7 3700X EIGHT CORE 4.4GHZ
- Cooler Master Hyper 212 (120mm) RGB
- Gigabyte GEFORCE RTX 2070 SUPER WINDFORCE OC
- Patriot Viper Steel 16GB (2x 8GB) 3600MHz DDR4 C17
- Corsair RM750x 750W
- WD BLUE SN550 250 GB NVME M.2
- WD BLUE SN550 1 TB NVME M.2
- Phanteks Neon Digital RGB LED Strip
- AOC CU34G2X/BK 3440X1440 VA 144HZ Curved gaming monitor.
I've also still got 2x 2TB SSD's that I'm keeping for in the new set up.
This should be a nice little upgrade from my current Intel Core i5 3570K, AMD Radeon HD 7900 and some old 24" 60hz Philips monitor set up...
The only thing I'm not changing is my case (Thermaltake Overseer RX-I), mainly because I still like the looks, but also because I failed to find anything I liked with a 5'25 bay for my blue ray player.
My current case is quite messy with loads of wires everywhere, partly because I've got this Lian-Li TR-5 fan controller and a multicard reader in there as well (don't like empty/unsed bays) and partly because I've not used any cable ties or anything.
I want the new set up to look neater so I've bought some cable ties, and a RGB LED strip to go somewhere instead the case as well.
I have put together my current set up from scratch, but that was 8 years ago, and I am a bit nervous about doing it again, especially after spending quite a bit on all components, so some guidance on where to start and what to do first would be great.
Obviously start with taking all current components out, and then giving the inside and outside of the case a good clean and making it dust free. And then start building...
Does this sound about right ?
1) Attach CPU cooler mounting frames to motherboard.
2) Screw motherboard into the case
3) Attach CPU and CPU cooler to motherboard
4) Click in the memory strips.
The 4 slots available are DDR4_A1 & DDR4_A2, and DDR4_B1 & DDR4_B2. Which ones should i go for again ?
5) Click in the 2x NVME M.2 SSD's (i want to use the 250GB for Windows 10)
There's an M2A socket, and M2B socket, I take it stick the one i want to use for my OS in slot A, which for some reason seems to have a 'thermal guard' over it then i need to unscrew and lift up first...
6) Click in the GPU into the PCIEX16 slot
7) Install the PSU
8) Connect up everything, stick the windows 10 cd in the blueray drive, and fire it all up ?
Am I right in saying it's best not to connect the 2x other sata drive (2 TB ones) at the beginning so there'll be less confusing on where to install windows 10 on, or will i just get a list of drives to chose from ?
And I'm not really sure what to do with all the RGB stuff (never heard of this before i started looking at upgrading i must admit), I've got a RGB CPU cooler, the GPU has 'something' RGB I believe, and then I've got that RGB light strip that I want to install. Do I all just click them in together somewhere on the mainboard or how does that work ?
Any tips/pointers, or common 'what not to do' very welcome!
7) Install the PSU
