Hi - I'm hoping someone with more knowledge than myself can comment on these pics.
Context
- looking to purchase next home, ticks all boxes, about to submit offer and noticed this crack in one of the bedroom walls (during 2nd viewing)
- 1985ish house, detached 4-bed, bryant built
- This wall is above a double garage, and is supported by a breeze block wall running down the middle of the garages
The crack
- as per pic it runs down from the window sill to just above the radiator, I could just about squeeze a thin coin inside. It's more than a hairline surface plaster crack (my current house is full of those after a re-skim some year ago), but I cannot tell if its just the plaster, of if the inner skin brick work has moved underneath
- The skirting on the room also shows some cracking along the upper joint with the wall, highlighted in pic
- Inspecting the wall underneath shows some work has been done on the two red bricks highlighted, which is directly below the radiator
Before I lump up the pennies for a pre-offer surveyor, does anyone want to take a shot at this one? Possible root cause, or how best to find someone qualified to comment for 30 minutes! Appreciate the pics and info is not a huge amount to go on, just trying to find a sounding board!
Thanks
Context
The crack
Thanks
