@144Hz very likely will bottleneck it.Is Ampere likely to be bottlenecked by a Ryzen 1700? I thought about upgrading my GPU before thinking about CPU or motherboard at a later date.
How much do you think a 1080ti, 3 fan, partner, card will get me come Oct.? £300 way too much to expect?
Why would you buy the most expensive Ampere to game at 1080p? and the moment you switch up to 1440p and 4K you won't bottle neck any reasonable recent CPU
Cool, let us know how you get on. I'd be interested to know how your 1700 copes with the games you throw at it.![]()
talk of 1080Ti (and above) in the same context as 1080p makes me sad. Ok ok I know I shouldn't judge and yes there are competitive cases where very high frame rate leads to an in game advantage etc etc.... but 1080p come guys really? SVGA monitors weren't far off that back in the 90's for goodness sake that's like 25-30yrs ago![]()
that sounds like an issue with the game rather than the hardware, hell even my 980Ti runs games like Elite @4k within acceptable framerates maybe not 60fps all the time but not far offIf i start pushing setting up, even with a RTX2080, at 1080p, is not that easy to always, in every game, maintain a 60fps (with no drops).
How are you finding your 3700x with your 1080ti? What did you upgrade your CPU from? Have you noticed any change in minimums etc??
The GPU will dynamically utilize bandwidth from: system RAM, VRAM, and SSD to execute multiple tasks simultaneously at a much higher speed.
Hey! I'm still on 1080 lol, i wouldn't mind a 1440p but the ones i want are a little out of price range currentlytalk of 1080Ti (and above) in the same context as 1080p makes me sad. Ok ok I know I shouldn't judge and yes there are competitive cases where very high frame rate leads to an in game advantage etc etc.... but 1080p come guys really? SVGA monitors weren't far off that back in the 90's for goodness sake that's like 25-30yrs ago![]()
yay more MILD made up stuff
Actually this could help, in simple terms using the System Ram and SSD as texture cache would help with performance as its effectively adding memory capacity and bandwidth to the GPU.
The PS5 is known to use a similar approach which suggests AMD RDNA2 GPU's have this too.
Its not just fluff.![]()
AMD already had the Radeon SSG for certain workloads,so wouldn't be surprised if Nvidia does something such as NVCache.
Is that the GPU with an SSD on the card?
Have AMD ever made a "Titan" card, something a little special with something a little special about it?
Yes here it is.... https://www.amd.com/en/products/professional-graphics/radeon-pro-ssg
It has a 2TB, (that's 2048GB) SSD on the PCB, first card to use this tech.
I'm sticking my head on the block here but I think with RDNA2 AMD are back with a bang at the top end and i think it might be fun if they had a Titan style card that actually was something really special, the biggest badassed GPU with all of AMD latest tech all over it.![]()
