Thanks @mrbell1984, you're a star.
What site are people using to host their sigs? The one I use (and many others here) seems to no longer work. I'm assuming all my sigs are lost too.
Which site is that? You mean sigrotor? I’ve contacted the host to see if they would give me the script fully but no response and they don’t visit this site any more I don’t think.
I host the sigs myself (if they are rotating ones).![]()
Yeah http://sigrotor.com/
I tried to contact them months ago via that site but seems it's no longer maintained. I'll have to find a host for some rotating sigs and post back here soon!
I don’t know the urls it used to store the sigs as I could have pulled them all from the site.
Give me your sigs n I’ll host them for you.
@Lethal I have requested help from this forum for coders to replicate a better sigrotor system for this forum! Please if anyone can help head over to:
https://forums.overclockers.co.uk/threads/sigrotor-coding-help.18891678/
@.Lethal Trying to do your new sigs but the font is very strange. Looks odd. I'll show you in a sec.
The third FF7 remake you wanted won't really fit on 400 x 75 because of the resolution size. When I make it smaller it looks very odd in 400 x 75.
Those are great! The only thing I'd ask is if you could add my username to the other 2 sigs in the bottom corner and make the font for the FF one smaller and in the bottom left corner. Sorry to be picky! The borders are awesome.
Remove my quote from above, how does this look with the font smaller in bottom left?
Amazing... BUT, don't hate me.. could you move the username for the Diablo sig to the bottom right side instead of the left please![]()
alright done. Your url is https://sigs.ocukrogues.ml/lethal.jpg (This might be temp if I can get a good sigrotor up and running)
No rush at all, I'm not looking to push my luck![]()
Done, it's now in your rotor.![]()
I was just browsing and saw this appear in my sig! That was fast!
Love it, appreciate all the work
  I wont be disappearing anytime soon from here that's for sure unless something happens to me.
if it is possible with the guy with a bird on his arm and the woman holding a skull,
