Hi all,
Following on from some solid advice over on this thread by @Sparx https://forums.overclockers.co.uk/threads/4k-res-gaming-rig-queries.18894329/#post-33793768 on components to go towards a 4k PC rig (Or at least get close to it right now)
My components arrived yesterday to start my build & eventually turn it into something capable of running smooth frames at 4k.
Spec:
CPU - AMD Ryzen 9 3900X Twelve Core 4.6GHz
CPU Cooler - Corsair Hydro Series iCUE H115i PRO XT RGB Performance Liquid Cooler - 280mm
MOBO - Gigabyte X570 AORUS ELITE (AMD AM4) DDR4 X570
RAM - Corsair Vengeance RGB PRO Black 16GB (2x8GB) 3600 MHz AMD Ryzen Tuned DDR4
SSD - WD Black 1TB SN750 M.2 2280 NVME PCI-E Gen3
GFX - 1070 8gb (Pending the 3080 TI being released in September)
PSU - Corsair 1000W Gold
Case - Phanteks Eclipse P500 Air ATX
Monitor - ASUS ROG STRIX XG27UQ 27" 3840x2160 IPS 144Hz 1ms FreeSync/G-Sync Compatible HDR400
Current Rig setup + Office working from home!
New components
First step:
Open up the Mobo box, and flick through the guides in case there is anything odd in there...
Noted nothing out of the ordinary. Although it did come with a CD with its drivers on.
Had an issue with seating the RAM. The first slot saw the holding pin snap off on one side (Started to think... oh it's going to be one of those builds is it)
Then got to the NVME SSD, so find that it's shorter than (What I assume is a protective cover on the Mobo when you get it set in?)
I didn't want to seat the CPU just yet, as I also had a screw snap its head when seating the Mobo which was not good news! May need new decent screws to avoid seating issues.
Queries on next steps:
Spec:
New components
- NVME/SSD installation - Whilst there is another round pin slot to align with the shorter SSD strip, how on earth do I get the holding pin out of slot "110" to place it into "80" closer up? I unseated the mobo but can't seem to get it out at all from the backside either.
- I'm also struggling on the knowledge front, of when I do get everything seated and installed.... Where do I start in regards to drivers? The mobo came with a disk, but I have no optical drive. Whilst in order to instal drivers online, surely I need a working Mobo for wifi, let alone an OS installation? I suppose what I'm really asking, is what are my steps after the physical instal?
Many thanks,
Luvvo
Lol. You need to change the RAM order anyway, you want them in slot A2 and B2 so they run dual-channel correctly. So they're both further away from the CPU slot
