Ram upgrade advice needed
5 May 2014
Hi all, I bought a pc from overclockers back in 2014 and its still going strong, upgraded the gpu a couple of times but now im thinking of upgrading the RAM
Im currebtly running with TeamGroup Vulcan GOLD 16GB (2x8GB) DDR3 PC3-17100C11 2133MHz Dual channel kit.
I would like to add another 16GB of RAM but I cannot find this exact RAM anywhere on the net, so would I be ok to change brand/MHz etc? Any recommendations would be greatly appreciated.
**edit** Is it even worth upgrading the RAM? Or should I be looking at a new build?
15 Oct 2019
Uk
Yeah, probably not worth going with 32gb now on a PC that old unless you really need it for video editing or something.
30 Jul 2007
Lincolnshire
If just for gaming 16GB is plenty mate - won't get any performance boost going 32GB unless you do 3D rendering/editing work etc.
As El Jimben said what's rest of your PC specs? Do you have an SSD? That would really help boost performance if you don't have one.
