Z390 Aorus Master draining CMOS batteries.
21 Jun 2006
UK
Basically the board is eating CMOS batteries.
This is the fourth battery I've put into it now since June but they seem to drain rapidly, ranging from a few days to a week.
I've tested the batteries prior to installation and the voltages have been fine.
I've tried resetting the bios and am currently running the latest version but it doesn't seem to make any difference.
18 Jan 2006
Norwich
Crap batteries?
If you're using discount store or eBay / Amazon batteries try a decent Duracell or Energizer bought from a proper shop.
There are plenty of fakes about, and anything from the discount stores is generally not the same as stuff bought elsewhere.
15 Oct 2005
Earth, for now
Strange one for sure. I can't remember when I last replaced a battery on a motherboard. I take it that when you power down the PC it is still connected to the mains, silly point perhaps. AFAIK when you power down a PC it still draws power from the PSU and only uses the battery when the board is out of the PC or not plugged into the mains. Could be wrong on that tho. Even if the above was correct to need to replace it in a matter of days is just wrong.
Even tho the PC might show RTC errors, or something else to make you change the battery, is it actually dead when testing it...?
OP
21 Jun 2006
UK
I should add this only happens when the pc is turned off at the wall.
If I leave it switched on there is no issue.
When checking the batteries from memory they have drained to around 2.3v
OP
21 Jun 2006
UK
Crap batteries?
They weren't a name brand, i've got some energizer ones being delivered today
15 Oct 2005
Earth, for now
Not that you shouldn't be able to but why do you switch off at the wall...? The PC needs that constant power source for its RTC etc. For all I know my battery might be a problem, but I don't leave it as you do to find out.
Don't think that this matters but some USB ports on this board can be live even with the power off, to charge devices etc.
My Z390 Master has been fine since new, but left plugged in.
15 Oct 2005
Earth, for now
oh my :D
That is probably the power needed to to retain its settings etc, apart from RGB stuff - if used.
With what you have spent on batteries that would have probably paid for the elec bill for the entire year, and the rest.
OP
21 Jun 2006
UK
It's ate yet another CMOS battery (energizer), weirdly the pc turns on briefly when power is applied at the wall then turns off until I press the power button.
15 Oct 2005
Earth, for now
Do you mean that it has drained your new energiser battery whilst still powering the PC off at the socket each day...? You had mentioned previously that if you left it switched on at the socket all is well.
IIRC when I have needed to remove the power from the PSU mine will momentarily go through a sort of power on / off cycle. It doesn't like being turned off from the wall it seems.
5 Feb 2009
N. Ireland
is this a new build and has been happening since day one or is it a recent anomaly?
only ask as i was finding a similar issue (along with a few others) a couple of years back with a new build. turned out the board was unduly twisted slightly. correcting this sorted the batteries seemingly draining along with the other problems i was seeing. are you experiencing any other problems with the build?
OP
21 Jun 2006
UK
Its been OK for a month or two and then the issues started.
No other issues to report, its been brilliant.
When you say twisted, what did you do to fix it? Its fitted to the standoffs correctly.
5 Feb 2009
N. Ireland
that probably rules out the issues i was having as mine were probably within a few days/couple of weeks.
when i say twisted what i meant was one of the prefitted standoffs in the case was a tad low compared to the others. i had absentmindedly just screwed the motherboard in anyway and was only when another user mentioned taking everything out and building outside the case (the screw pinged off like a dart once i unscrewed it) that i realised the problem.....used a couple of small plastic washers to fill the gap and stop the motherboard flexing and all has been solid since. there wasn't even that much of a flex so they are very senstive to any deformation.
